DimON Опубликовано September 14 Жалоба Share Опубликовано September 14 On paper, the choice between the F65 MINI Cooper Five-Door and the U25 Countryman looks straightforward. One is a small hatchback with extra doors, the other is a small crossover with extra everything. In practice the decision is more nuanced than that, and getting it wrong in either direction is easy. Buy the Five-Door when you needed the Countryman and you’ll spend the next three years wishing for more space. Buy the Countryman when the Five-Door would have done the job and you’ll wonder why your MINI feels less like a MINI every time you take a corner. This is the comparison that helps you get it right. Real specs, real size differences, honest driving impressions, and a clear answer for different types of buyers. Size: The Gap Is Bigger Than You Think This is where the comparison starts because it’s where the decision is most often made, and the numbers are more dramatic than most buyers realise before they see the two cars in the same car park. The F65 MINI Cooper 5 Door The F65 Cooper Five-Door measures 161.5 inches in length, 70.2 inches wide, and 56.6 inches tall. It is, in every meaningful sense, a small car. Compact enough for tight urban parking, narrow enough for single-track country roads, and low enough that it still reads as a hatchback rather than a crossover from any angle. SpecF65 Cooper Five-DoorU25 Countryman S ALL4DifferenceEXTERIORLength158.9 in / 4,036 mm174.8 in / 4,440 mm+15.9 inWidth (without mirrors)68.6 in / 1,744 mm72.9 in / 1,852 mm+4.3 inHeight57.6 in / 1,464 mm63.5 in / 1,613 mm+5.9 inWheelbase101.7 in / 2,583 mm105.7 in / 2,685 mm+4.0 inCurb Weight (S variant)3,130 lbs / 1,420 kg3,682 lbs / 1,670 kg+552 lbsFRONT PASSENGERHeadroom40.3 in40.7 in+0.4 inLegroom41.4 in40.4 in-1.0 inShoulder Room51.2 in55.7 in+4.5 inREAR PASSENGERHeadroom36.9 in39.1 in+2.2 inLegroom30.8 in37.0 in+6.2 inShoulder Room49.1 in54.8 in+5.7 inCARGOSeats Up9.7 cu ft / 275 L24.9 cu ft / 705 L+15.2 cu ftSeats Down40.7 cu ft / 1,153 L56.1 cu ft / 1,589 L+15.4 cu ft The U25 MINI Countryman The U25 Countryman is a fundamentally different proposition. It grew nearly eight inches over its predecessor the F60, mostly behind the rear wheels, following the BMW X1’s template more closely than any previous Countryman. The result is a car that competes directly in the small crossover segment against the Volkswagen Tiguan, the Mazda CX-5, and the BMW X1 itself. It is not a large car by crossover standards, but next to the Five-Door it is unambiguously a different size class. The practical implications of that gap are significant. Rear legroom in the Countryman is genuinely comfortable for adults on longer journeys in a way the Five-Door can’t quite match. Boot space in the Countryman is considerably larger, and the higher seating position adds an ease of entry and exit that matters more than it sounds over the course of daily use. If you regularly carry adults in the back seat, or travel with more than an overnight bag, the Five-Door will ask you to compromise in ways the Countryman won’t. The flip side is that the Countryman’s size costs you in urban environments. Parking a U25 in a tight city space requires more attention and more maneuvers than the F65. The Five-Door slots into gaps the Countryman has to think about. For buyers in dense metro markets, that difference is felt every single day. Specs: Two Very Different Powertrains Both cars share the same B48 four-cylinder engine family in their respective S variants, but the way those engines are deployed tells you a lot about how differently MINI has tuned these cars. The F65 Cooper S produces 204 horsepower and 221 lb-ft of torque, channelled through a 7-speed dual-clutch transmission to the front wheels. It is a front-wheel drive car, full stop, which is both a philosophical statement and a practical one. The F65 Cooper C, the entry variant, produces 161 hp in markets with four cylinder and 154 with the three cylinder. The Countryman S ALL4 also uses the B48 but adds all-wheel drive as standard, reflecting both the car’s crossover positioning and the expectation that its buyers are more likely to encounter genuinely varied road surfaces. The Countryman JCW ALL4 goes further still, producing 315 horsepower and all-wheel drive, making it the most powerful production MINI ever built. The JCW’s performance numbers are impressive but still down slightly on the JCW Clubman from the previous generation. It is worth noting that the Countryman C (where available) uses a 155 horsepower three-cylinder coupled with a 19 horsepower electric motor producing a combined 167 horsepower, a mild hybrid system that the base Five-Door does not share. For buyers focused on efficiency at the entry level, that distinction might matter. Price: The Gap Widens Quickly The F65 Cooper Five-Door starts around $30,000 for the Cooper C, with the Cooper S coming in around $34,000 before options. Properly specified with the packages worth having, a well-equipped Five-Door Cooper S lands in the mid-to-high thirties. ModelTrimBase MSRPF65 MINI Cooper Five-Door (US market)Cooper C$30,500Cooper S$33,800U25 MINI Countryman (US market)Countryman S ALL4$38,900Countryman SE ALL4 (EV)$47,800Countryman JCW ALL4$46,900 The Countryman S ALL4 starts at $38,900, and the JCW ALL4 opens at $46,900. A fully loaded Countryman in JCW trim with meaningful options can push north of $55,000, which is territory that puts it in direct competition with entry-level BMW X1 and X3 territory, a fact that is either entirely appropriate given the platform it shares with the X1 or mildly alarming depending on how you feel about where the MINI brand has positioned itself. The price gap between a well-specified Five-Door and a well-specified Countryman S is roughly $8,000 to $10,000 at equivalent trim levels. That is a meaningful number, and for buyers who don’t genuinely need the Countryman’s extra space and all-wheel drive capability, it represents real money spent on attributes they may rarely use. Driving Experience: Where the Cars Diverge Most This is the most important part of the comparison for any reader of MotoringFile, and it’s where the two cars tell very different stories. The F65 Five-Door is, at its core, still a MINI in the way that word has meant something since 2001. The chassis communicates. The steering has enough weight and feedback to make corner entry genuinely satisfying. The go-kart feeling that has defined the brand’s identity is present in the Five-Door in a way that is diluted but not destroyed by the extra length and two additional doors. Our review of the Cooper S Five-Door found that it preserved MINI’s playful dynamics while finally delivering the everyday usability many buyers were looking for. That’s a harder balance to achieve than it sounds. The Countryman is a different exercise entirely. It is a well-engineered small crossover that happens to have MINI’s design language and some of MINI’s character, rather than a MINI that happens to be large. Engineers have done an excellent job hiding the extra size and mass present in the U25, and the JCW version in particular is genuinely fast and capable in ways that surprise. But the fundamental physics of a 3,825 pound all-wheel drive crossover on a platform shared with the BMW X1 mean that the Countryman asks different things of its driver than the Five-Door does. It rewards smoothness and confidence rather than the sharp, immediate inputs the Five-Door responds to so well. That is not a criticism. It is a description. The Countryman is a very good car. But if what you want is the most MINI-like MINI that still has a usable back seat and a practical boot, the Five-Door is the answer and the Countryman is a different product category wearing the same badge. Who Should Buy Which Buy the F65 Cooper Five-Door if: You live in a city or dense suburb where parking is a daily consideration. You want the most driver-focused MINI available in a practical package. Your rear passengers are occasional rather than regular. Your budget is closer to $35,000 than $45,000. You value the go-kart feeling above everything else and are willing to accept a smaller boot to keep it. Buy the U25 Countryman if: You regularly carry adults in the back seat on journeys longer than twenty minutes. You want or need all-wheel drive for your climate or terrain. You travel frequently with luggage, sports equipment, or anything that requires genuine boot space. Your budget comfortably reaches $40,000 or above. And you don’t mind giving up a little of that go-kart feel for this extra flexibility. The middle ground: For buyers genuinely torn between the two, spend a day driving both back to back rather than on separate visits. The difference in character is immediately apparent behind the wheel in a way that no comparison article can fully convey. The Five-Door will surprise you with how much it feels like a proper MINI despite its extra size. The Countryman will surprise you with how accomplished and refined it is as a crossover. Which surprise you enjoy more is probably your answer. The third option: The Used Clubman Alternative There is a third option worth mentioning for buyers who find themselves caught between the Five-Door and the Countryman on price or practicality: the outgoing F54 Clubman, which ended production in 2024 and is now appearing on the used market in increasing numbers at compelling prices. The Clubman was never a perfect car, but it occupied exactly the space between these two models that no current MINI fills. Longer than the Five-Door with proper rear-hinged barn doors, a genuinely usable boot, and available ALL4 all-wheel drive, it offered much of what the Countryman delivers in a lower, more hatchback-like package that preserved more of the Cooper’s driving character. We covered it extensively throughout its production run and remain convinced it was one of the most underappreciated MINIs of the modern era. A well-specced F54 Clubman S ALL4 with low miles can now be found in the $25,000 to $32,000 range, which undercuts both the Five-Door and the Countryman while delivering a driving experience that sits comfortably between them. For buyers who aren’t locked into new, it deserves a serious look. For deeper dives on each car individually, our F65 Five-Door coverage and complete U25 Countryman buyer’s guide cover everything you need to know before making the final call. The post MINI Cooper 5-Door vs Countryman: The Smart Buy for Those Who Need More MINI appeared first on MotoringFile. View the full article Ссылка на комментарий Поделиться на другие сайты More sharing options...
