2026 MINI Countryman Buyer’s Guide: Every Model, Every Trim, and What to Buy
The 2026 MINI Countryman is the best version of the model MINI has ever built. It’s also the most complicated to buy. Three models, three trim levels, three style packages, and in the US, a market context around the electric version that has shifted considerably since this generation launched. This guide cuts through all of that.
Note: We’ll walking through US, UK and European market details in that order.
Understanding How MINI Structures the Countryman
Before getting into specifics, a quick orientation on how MINI builds its pricing. You start with a model, which determines powertrain and performance. You then add a style, which sets aesthetics and some chassis hardware. Finally you choose a trim level, which determines technology and equipment. These three decisions are made independently and in combination, which is where most buyers get confused. This guide will walk through each one.
The Models: US Market
The US Countryman lineup consists of three models. MINI does not offer the entry-level Countryman C or the single-motor electric Countryman E in North America. The S ALL4 is the entry point, the SE ALL4 is the only EV, and the JCW ALL4 sits at the top.
ModelPowertrainDrivePower (US Spec)0-60 mph
Countryman Oxford Edition2.0L turbo petrolAWD241 hp6.2 sec
Countryman S ALL42.0L turbo petrolAWD241 hp6.2 sec
Countryman SE ALL4Dual electric motorsAWD309 hp5.4 sec
Countryman JCW ALL42.0L turbo petrolAWD312 hp5.2 sec
Note: US petrol models do not use the mild hybrid system fitted to European versions. MINI USA chose to skip it, keeping weight and complexity down while gaining a small power advantage. The result is that the US Countryman S makes 241 hp versus the European S at 218 hp, and the JCW reaches 312 hp versus 300 hp in Europe.
The Countryman S ALL4 is the sweet spot of the range for most buyers and the one we’d point the majority of people toward. It makes as much torque as the JCW (295 lb-ft) while coming in considerably cheaper and offering more interior and exterior styling flexibility. The performance gap between the S and JCW in everyday driving is narrower than the price difference suggests. For most buyers this is the rational and still genuinely enjoyable choice.
The Oxford Edition is new for 2026, an S ALL4 priced $4,000 lower with a simplified color palette and limited configuration options. For buyers who want the Countryman experience without the complexity or cost, it’s worth considering.
The Countryman SE ALL4 is the electric model and in our extended review, the best daily driver MINI has ever made. The throttle calibration is smooth and intuitive, making stop-and-go traffic feel almost effortless. The brake pedal blends regenerative and friction braking with rare consistency. OS9’s navigation integrates battery state, predicted consumption, and charging infrastructure in a way that makes trip planning easier than any phone-based solution. Charging peaks at 130 kW with a 10-80 percent session taking under 30 minutes in good conditions. The March 2026 production update added a silicon carbide inverter, increased usable capacity to 65.2 kWh, and reduced-friction wheel bearings, improving on the original 212-mile EPA range.
There is, however, significant context US buyers need to understand. Federal EV incentives are gone. As we confirmed late last year, MINI USA is no longer building the SE for dealer stock. It is now build-to-order only, meaning no spontaneous showroom purchases, limited test drive availability, and a longer wait. The SE remains worth it if you can charge at home and your daily patterns support it. But it requires more planning and a more deliberate buying process than the petrol models. As we examined in depth, the SE is the ideal Countryman for most daily drivers. The challenge is a market environment that has made the buying process more complicated than the car itself.
The Countryman JCW ALL4 is the performance flagship. It’s visually distinct, genuinely quick, and the only way to get the full JCW package without the S with JCW Style workaround. The honest caveat is that the S carries the same torque figure in everyday driving, costs significantly less, and offers more personalization flexibility. The JCW makes sense if outright performance and the full visual statement are priorities. Buyers who go with an S and JCW Style give up very little for considerably less money.
MINI Countryman Styles
Styles set the visual and material character of the car, and are chosen before trim level. Think of them as: one is dark, one is light, one is sporty.
StyleInterior CharacterKey AdditionsAvailable On
ClassicMatte black trim, darker overallSmaller 18″ wheelsS, SE, JCW
FavouredVibrant Silver accents, lighterSpace-saver spare, factory tow hitchS, SE only
JCW StyleJCW-inspired, sportyAdaptive dampers, shift paddles, JCW aero kit, uprated brakesS only
Favoured is the most practically useful choice for most buyers. The factory tow hitch and space-saver spare are genuinely valuable additions that no other style includes. JCW Style is the right move for driver-focused S buyers, the adaptive dampers and paddles meaningfully change the car’s back-road character. At Iconic trim the price gap to a base JCW narrows enough to be worth doing the math first.
Countryman Trim Levels: US Market
MINI USA eliminated the base Signature trim for 2026. Signature Plus and Iconic are the two options.
TrimKey Additions Over BaseApproximate Price Premium
Signature PlusHead-up display, core driver assistance, heated seatsIncluded in base price
IconicHarman Kardon audio, Driving Assistant Plus, power seats, interior camera+$3,200 (S) / +$2,400 (JCW)
Signature Plus is the sweet spot for most. Iconic is worth it if you want the complete technology package and won’t second-guess the cost. Fully optioned Iconic trims push into the low to mid $50,000 range, which is worth knowing before you start clicking boxes.
MINI Countryman US Pricing
ModelBase MSRPSignature PlusIconic (approx.)
Oxford Edition$34,900N/AN/A
Countryman S ALL4$40,500Included~$43,700
Countryman SE ALL4$45,200Included~$48,600
Countryman JCW ALL4$46,900Included~$49,300
All prices exclude the $1,175 destination fee.
What Countryman to Buy: US
For most enthusiast oriented buyers we’d recommend the Countryman S ALL4, Signature Plus, JCW Style. Same torque as the JCW, meaningfully cheaper, enhanced driving character with the adaptive dampers and paddles. Around $44,000.
For daily drivers who can charge at home: Countryman SE ALL4, Iconic, Favoured. Order rather than walk in expecting stock as MINI USA has ramped down imports after the EV incentives were ended early last year. But make no mistake, this is the best daily driver you can buy in MINIs line-up if it fits your lifestyle.
For performance and presence: Countryman JCW ALL4. Go in knowing the S with JCW Style closes the gap considerably for less money.
For those looking for a great deal, look no further than the MINI Countryman S Oxford Edition. Incredible value for money with plenty of popular options – albeit with limited customization.
UK and European Buyers
The Countryman lineup is broader outside the US, and the entry points are meaningfully different. Both the Countryman C, a 170 hp mild-hybrid petrol with front-wheel drive, and the Countryman E, a single-motor front-drive electric, are available in the UK and Europe but not in North America. These expand the range downward in both price and complexity, making the buying decision quite different.
A note on pricing: UK prices include VAT at 20 percent and European prices include local VAT, which varies by country. These are not directly comparable to US prices on a currency conversion basis. A £32,000 Countryman S in the UK is not the same financial proposition as a $40,500 S in the US once tax treatment, standard equipment levels, and market positioning are factored in.
UK Models and Pricing
UK trims use Classic, Exclusive, and Sport grades, with three option packs layered on top. Level 1 (£2,800) covers wireless charging, auto-dimming mirrors, and high-beam assist, and is standard on S, SE, and JCW. Level 2 (£5,300) adds Harman Kardon audio, panoramic roof, and navigation. Level 3 (£7,500) brings augmented reality navigation, heated electric seats, and Driving Assistant Professional.
ModelPowertrainDriveStarting Price (OTR)
Countryman C1.5L mild-hybrid petrolFWDfrom £29,100
Countryman S2.0L mild-hybrid petrolAWDfrom £32,500
Countryman JCW2.0L petrolAWDfrom £44,030
Countryman ESingle electric motorFWDfrom £29,000*
Countryman SE ALL4Dual electric motorsAWDfrom £32,700*
*Electric prices reflect the £3,750 UK Government Electric Car Grant where applicable. Verify current grant status at time of purchase as eligibility criteria apply.
The Countryman C is the genuinely interesting entry point in the UK. Front-wheel drive and a 1.5-litre mild hybrid sounds modest, but at £29,100 it gets you the full U25 interior experience, the circular OLED display, the redesigned seats, and the fundamental character of the new Countryman at a price that undercuts almost everything in its class. For urban and suburban buyers who don’t need all-wheel drive, it’s worth serious consideration. Similarly, the Countryman E offers the EV experience from the same starting point as the C, with post-grant pricing making it one of the more accessible entry points into a premium electric SUV.
European Pricing (approximate, including local VAT)
European pricing varies by country. These figures are indicative based on German market pricing as a reference point.
ModelApproximate Starting Price (Germany)
Countryman Cfrom €36,900
Countryman Sfrom €40,900
Countryman JCWfrom €52,900
Countryman Efrom €43,900
Countryman SE ALL4from €48,900
European buyers should verify local incentives for electric models, which vary significantly by country and can materially change the SE and E value proposition versus petrol alternatives.
One More Thing Worth Knowing: The LCI
The U25 Countryman has not yet reached its mid-cycle refresh. Based on our source reporting, the full LCI covering both ICE and EV models is expected in July 2028, with meaningful interior and exterior updates. Between now and then, rolling technical improvements will continue, particularly on the EV side. If you’re buying an SE in any market, confirm your vehicle’s production date to ensure you’re getting the post-March 2026 hardware update with the improved range and efficiency figures.
The 2026 Countryman is a genuinely good car in a segment that doesn’t reward merely good. MINI’s combination of distinctive design, strong standard equipment, and BMW-shared engineering at a lower price than the X1 makes it one of the more defensible value propositions in compact premium SUVs. The key is knowing exactly which version you’re buying and why.
The post 2026 MINI Countryman Buyer’s Guide: Every Model, Every Trim, and What to Buy appeared first on MotoringFile.
