Review: The CravenSpeed Gemini Phone Mount
The world is full of cheap plastic phone mounts that squeeze into a vent or stick on a dash. But one has earned a reputation as the opposite of that. The CravenSpeed Gemini phone mount looks and feels completely different because it is. But can this all metal mount live up to its $75 price? We wanted to find out.
Designed and made in the US from 100% high-grade steel, the Gemini phone mount has all the hallmarks of a product that is made by people who care. Case in point, the brackets themselves are laser cut and powder coated steel. The result is incredible structural rigidity that keeps the phone stable. Then the bushings are press fit into the brakes which further adds to the overall stability of the mount.
There are two components to the system – the mount and the bracket. The scissor mount is one we didn’t test but is the most universal as it can expand and contract to any mobile device. Given that we primarily use an iPhone 15 Pro Max we tested Cravenspeed’s two magnetic mounts; the CraveSpeed’s own Magnetic mount and the MagSafe version. It’s important to note that the MagSafe mount is actually just a round enclosure that is designed to place a MagSafe charger into.
phone mount
Installation on our F56 took about 20 minutes and was extremely straightforward. The process revolves around removing the center cluster and reusing screw points where the plate is then mounted. CravenSpeed provides both the small Torx screw driver and longer screws that make the job extremely easy.
That said I would highly encourage you have a magnetic grabber tool available just in case you drop a screw in the process. We say that because that’s exactly what we did when one slipped behind the plastic panel under the steering wheel. Luckily that piece is a press fit and easily removable.
phone mount
The Cravenspeed Gemini Mount with the Cravenspeed Magnetic Mount.
And yes, there are two versions of the plate for either the analog or digital versions of the 3rd generation MINI cluster.
For our first couple of days we used the MagSafe adapter which acts as a cradle for an Apple MagSafe charger you’ll need to provide. As an iPhone user it felt like a no-brainer as it would not only hold the phone but charge is. And on smooth highway roads the set-up worked perfectly. However on some of the more broken roads of Chicago we quickly found that the magnets in the Apple MagSafe Charger itself weren’t strong enough to keep the phone from flying (literally) from the magnet.
phone mount
The mount can be positioned to be more discrete or closer to your line of sight. It can also be pushed down to minimize it entirely.
After a few days of playing defense we decided switch from the MagSafe mount to Cravespeed’s own much stronger magnetic mount. That move transformed the experience in a few ways. On the positive side it’s rocking a 100% success rate for holding my phone over the worst roads. On the not so positive side I do have to stare at the Cravenspeed logo quite a bit. While it’s a great company and the logo certainly isn’t offensive, it would be nice to see it a touch smaller. But that’s coming from me, a fairly Type A designer who tries to eliminate as many logos as possible. There’s a good chance it won’t bother you.
phone mount
The Most Over Engineered Mount Possible
The Cravenspeed Gemini mount has been a huge add to the cabin of our non-CarPlay F56. The placement, adjustability and quality puts it at the pinnacle of phone mounts we’ve tested or even seen. In short this thing is over-engineered in ways that is rare in consumer products these days. There’s simply nothing better on the market that we’d want in our MINI. It’s not cheap but for $75 you get the ultimate phone mount that will likely outlive your MINI itself. In our minds that’s not a bad bargain.
The post Review: The CravenSpeed Gemini Phone Mount appeared first on MotoringFile.
Link to comment
Share on other sites
 Share
