DimON Опубликовано вчера в 11:21 Жалоба Share Опубликовано вчера в 11:21 The MINI Cooper that suits you has less to do with trim level than with the code stamped on the engine. Twenty-five years of hatchbacks have produced some of the best small cars of the century and a few genuinely expensive lessons, and the two are not evenly spread across the generations. This guide covers the three-door MINI Cooper hatch across the R50, R53, R56, F56 and F66, with the Cooper, Cooper S and John Cooper Works (JCW) compared side by side. Think of it as the map rather than the territory. Each generation has its own full MotoringFile buyer’s guide, linked as we go, and what follows is the short version so you can decide which one earns the long read. Important notes: We’re sticking to the petrol Coopers in this guide so that means we’re not covering convertibles, EVs, the three JCW GP models or the R56 era Coupe and roadster models. We will tackle those aspects of the MINI range soon. Which MINI Cooper should you buy? The short answer There is no single best MINI Cooper, but there are clear best answers for specific buyers. These are ours, drawn from the individual guides we have published on each generation. If you wantBuy thisWhyReliability with the least dramaA 2016 to 2018 F56 Cooper with the manual and a documented service historyThe crankshaft recall is behind you, the three-cylinder is honest about what it is, and the exhaust is still pre-OPF. Details in our F56 buyer’s guide.The best driver’s car for the moneyA late-build F56 JCW or Cooper S with the six-speed manualThe Getrag GS6-59BG is the most capable manual MINI has built, and these cars are among the last stick-shift performance hatches in the segment.Character per dollarA 2005 or 2006 R53 Cooper SBy then BMW controlled parts sourcing, and the gearbox, trim and electrics were better. Condition beats mileage. See the R50 and R53 buyer’s guide.A turbocharged R56 that will not biteA post-LCI N18 Cooper S, or an N16 Cooper if reliability is the priorityEngine code matters more than mileage, trim or cosmetic condition. Our R56 buyer’s guide explains why.A new MINI CooperAn F66 Cooper S with the JCW Style packageMost of the JCW driving experience for less money and a lower insurance class in some markets. See the Cooper S vs JCW breakdown.The cheapest new Cooper that does not feel cheapAn F66 Cooper C Oxford EditionHeated seats, a heated steering wheel and more equipment bundled below the price of a standard C, covered in Cooper C or Cooper S. Notice what is missing from that table: the cheapest example of anything. Condition matters more than mileage on an R53, a cheap pre-LCI R56 Cooper S is rarely a bargain, and the F56 taxes neglectful buyers. The pattern holds across every generation below. MINI Cooper trims explained: Cooper, Cooper S and JCW The badges have stayed constant for a quarter century. What they mean has not. In the first generation the S was the headline act and the Cooper was the sensible one. By the F66, all three trims run a version of BMW’s B48 2.0-litre in North America, and the differences come down to calibration, torque and which options MINI will let you tick. GenerationCooperCooper SJohn Cooper WorksR50 and R53 (2001 to 2006)R50 Cooper: naturally aspirated Tritec 1.6, about 115 hpR53 Cooper S: supercharged Tritec 1.6 (Eaton M45), roughly 163 to 170 hpDealer-fitted tuning kit, around 200 hp, later a factory optionR56 (2007 to 2013)N12, then N16 1.6, naturally aspirated, about 118 hpN14, then N18 1.6 twin-scroll turbo, 172 hp (N14)Factory JCW with its own N14, N18 from the 2013 model year, Brembo four-piston front brakesF56 (2014 to 2024)B38 1.5 three-cylinder, 134 hp / 162 lb-ftB46, then B48 2.0 turbo, 189 hp / 206 lb-ftB48 2.0 turbo, 228 hp at launch and 231 hp later, 235 lb-ftF66 (2024 to present)North America: B48 2.0 turbo 161 hp / 184 lb-ftROW: B38 1.5 turbo 154 hp / 170 lb-ftB48 2.0 turbo, 201 hp / 221 lb-ftB48 2.0 turbo, 228 hp / 280 lb-ftNorth American figures A note on names. MINI says the C in Cooper C stands for Core, and the C and S badges apply to all petrol MINIs while E and SE mark the electric ones, as we first reported in our first look at the F66. The older codes are chassis designations: R50 for the first-generation Cooper, R53 for the supercharged S, R56 for the second generation, F56 for the third and F66 for the fourth. Our breakdown of what every MINI Cooper code reveals goes deeper. MINI Cooper specs by generation and trim Here is the full comparison. Weights are US-spec curb weights from our launch coverage, including the 2014 weight comparison, and the JCW weights come from our F66 JCW spec breakdown. Power figures for the R50, R53 and R56 shift slightly by market and year, so treat them as a guide and check the car in front of you. ModelTrimYearsEnginePower (torque)TransmissionsCurb weightR50Cooper2001 to 2006Tritec 1.6, naturally aspiratedAbout 115 hp5-speed manual, early CVT, later 6-speed automatic2,526 lbs (2,557 auto)R53Cooper S2002 to 2006Tritec 1.6, Eaton M45 superchargerRoughly 163 to 170 hpGetrag GS6-85BG 6-speed manual2,678 lbsR53JCWEarly dealer kit, later factory optionTritec 1.6, supercharged, JCW partsAround 200 hp6-speed manual2,678 lbsR56Cooper2007 to 2013N12 (pre-LCI), N16 (LCI)About 118 hpGetrag GS6-55BG 6-speed manual, Aisin 6-speed automatic2,535 lbs (2,612 auto)R56Cooper S2007 to 2013N14 (pre-LCI), N18 (LCI), 1.6 turbo172 hp (N14)Getrag GS6-53BG 6-speed manual, Aisin 6-speed automatic2,668 lbs (2,712 auto)R56JCWThrough 2013JCW-specific N14 until 2012, N18 for the 2013 model yearHotter tune, larger turbo6-speed manual2,658 lbs (2,701 auto)F56Cooper2014 to 2024B38 1.5 three-cylinder134 hp / 162 lb-ftGetrag GS6-59SG 6-speed manual, 6-speed automatic, then 7-speed DCT (2019 on)2,605 lbs (2,675 auto)F56Cooper S2014 to 2024B46, then B48 2.0 turbo189 hp / 206 lb-ftGetrag GS6-59BG 6-speed manual, 6-speed automatic, then 7-speed DCT2,760 lbs (2,795 auto)F56JCW2015 to 2024B48 2.0 turbo228 hp, later 231 hp / 235 lb-ftGetrag GS6-59BG 6-speed manual, automatic or DCT2,892 lbs (2,951 auto)F66Cooper C2024 to presentB48 2.0 turbo (North America)161 hp / 184 lb-ft7-speed DCT only2,778 lbs at launch (the North American C is a little heavier)F66Cooper S2024 to presentB48 2.0 turbo201 hp / 221 lb-ft7-speed DCT only2,832 lbsF66JCW2024 to presentB48A20O2 2.0 turbo231 hp / 280 lb-ft at 1,500 rpm7-speed DCT only (7DCT400)3,097 lbsNorth American figures MINI quotes 7.4 seconds to 60 mph for the F66 Cooper C and 6.3 for the Cooper S. Prices have moved too. The F66 Cooper launched at $28,950 against the final F56’s $25,800, the Cooper S at $32,200 against $30,900, and the JCW at $38,200. By mid 2026 we were quoting $29,900 for the C and $33,900 for the S before destination, so check our look at the 2027 lineup before you shop. R50 and R53 (2001 to 2006): the supercharged icon The first BMW-era MINI is the one that put the brand back on the map. The R50 Cooper was the sensible hatch, powered by the Tritec, a Chrysler-engineered iron-block four built in Brazil. The R53 Cooper S added an Eaton M45 supercharger, a six-speed Getrag manual and a whine that people either love or tolerate. Our R50 launch retrospective shows how fresh it all felt. Drive a well-sorted R53 today and it feels almost shockingly alive: immediate throttle, short gearing and a chassis that rotates with a playfulness modern cars have traded away for weight and screens. On paper, that is nostalgia. In practice it holds up, with one condition. These cars were never engineered for twenty-plus years of life, so condition matters more than mileage, and later years matter more than early ones. Inspect the supercharger first. Eaton no longer makes replacements and MINI has no plan to bring them back, so listen for bearing noise beyond the usual whine, look for oil seepage around the nose cone and ask about service and rebuild history. After that, the predictable problems: oil leaks from the crank seal and crank sensor O-ring, a coolant expansion tank that can split without warning (overheating can be fatal for an R53), and a power steering pump that was a weak point on early cars. Water is the sneaky one. Clogged sunroof drains can send water into the passenger footwell, where the body control module lives, and a shorted module turns the car into a very expensive paperweight. Gearbox choice matters as much as trim. The ZF CVT on early R50s sits at the bottom of our ranking of every MINI transmission and should be avoided outright. The early Midlands five-speed was fragile and vague, and the Getrag five-speed that arrived in 2004 is a huge improvement, which is why 2005 and 2006 R50 Coopers are so much more desirable. The R53’s Getrag GS6-85BG six-speed ranks third on that list, with short throws that charm on a back road and wear on you in traffic. Aim for 2005 to 2006. 2004 is a solid middle ground, while 2002 and 2003 can be great but carry more risk, particularly in the R50. The JCW is the transformative option. Early versions were dealer-installed kits with a modified head, upgraded intercooler, revised supercharger and an ECU remap for roughly 200 hp, and MINI later offered the kit from the factory. Factory provenance is easier to verify, but a tired JCW supercharger turns a collectible into a project. Our Cooper S vs JCW breakdown works through the premium generation by generation, and our ranking of every JCW GP covers the halo versions. Who it is for: someone who wants the most elemental MINI Cooper and will do the homework. Who it is not for: anyone who wants a car they never think about. The full inspection list lives in our Ultimate R50 and R53 buyer’s guide, and our R53 hub and R50 hub collect the rest. R56 (2007 to 2013): where MINI learned the hard way The R56 is the generation people warn you about, and the warning deserves more precision than it usually gets. It swapped the supercharged Tritec for the Prince family, co-developed with PSA: an aluminium block, plenty of new technology and a twin-scroll turbo on the Cooper S and JCW. Impressive on paper. In practice the engines are the whole story, and the story changes with the engine code. The Cooper is the safe one. The naturally aspirated N12 in pre-LCI cars is simple and generally durable (listen for timing chain noise on a cold start and check the valve cover for leaks), and the N16 that arrived with the 2011 LCI is the safest bet in the entire R56 range. The Cooper S is where it gets expensive. The pre-LCI N14 is the source of most horror stories: timing chain stretch, high-pressure fuel pump failures, carbon build-up from direct injection, turbo oil supply problems and cooling failures. The N18 that came with the LCI revised the timing system, crankcase ventilation and fuelling, and it tolerates real-world ownership far better. Then the JCW, where the fine print matters. The factory JCW hatch used a JCW-specific N14 with stronger internals, Brembo four-piston front brakes, a larger turbo and a chassis tune the Cooper S kit could not replicate. It did not get the N18 when the LCI arrived. From 2011 through early 2012, facelift JCWs still ran the N14, and the N18 version only appeared for the 2013 model year. A 2011 JCW wearing facelift bodywork can therefore carry first-generation risks. Verify the engine code, not the model year. Beyond the engine, the Getrag manuals are durable and the Aisin automatic is hit or miss, so a manual remains the safer choice. Suspension wear points (control arm bushings, dampers and wheel bearings) show up faster than on most small cars, and interior plastics peel and turn sticky. The better news is that rust is not the widespread structural problem it is on the R50 and R53. The call: an N16 Cooper for reliability, an N18 Cooper S for the best balance of speed and durability, and a JCW only if you have the diligence. A cheap pre-LCI Cooper S is rarely a bargain. Everything above is expanded in our Ultimate R56 buyer’s guide, and the R56 hub has the history. F56 (2014 to 2024): the Cooper that fixed it The F56 was supposed to be replaced around 2021. BMW’s decision to delay the fourth generation stretched it to a decade, and MINI facelifted the same car twice, which makes the F56 three cars in one skin. It was also the first Cooper built on BMW’s own UKL platform with BMW’s own B38 and B48 engines, a direct answer to the Chrysler-era hardware and borrowed French engines of the generations before. By 2017, MINI had gone a full year without a recall, which would have been unthinkable in the R56 era. Our UKL explainer covers how that decision was made. The three phases matter more than the model year. Pre-LCI1 cars (March 2014 to late 2018) are the cheapest and least refined. Early 2014 and 2015 Cooper S models were hit by a crankshaft bearing recall, and the quality of the rebuilds varied, so we would avoid them unless the paperwork is transparent. From 2016 the picture is substantially cleaner. The LCI1 (2019 model year) replaced the six-speed automatic with a seven-speed DCT, which hesitated early on until software updates arrived, so confirm they were done. US-spec Cooper S and JCW builds from before the OPF particulate filter arrived keep a louder exhaust, and build date, not model year, is what counts. The LCI2 (2022 model year) brought the styling MINI had held back and the final run of manuals. On the engines, the B38 three-cylinder in the Cooper is reliable and efficient but not the choice for enthusiasts. The B48 in the Cooper S is the generation’s strongest argument, durable across hundreds of thousands of owner miles with normal maintenance. The hotter JCW tune can consume oil under hard use, and its upper engine mount typically fails around 60,000 miles at a cost of $800 to $1,200. Control arm bushings get noisy with age, and the plastic thermostat and oil filter housings can leak. The six-speed manual in the Cooper S and JCW, the Getrag GS6-59BG, is rated for roughly 435 lb-ft in a car that makes 236, which explains its durability and its popularity with tuners. By 2023, more than half of US F56 JCW hardtops carried it, and our deep dive on that gearbox explains why. The interior deserves a mention too: for material quality, it remains MINI’s high-water mark. For the F56, MINI debuted a five door variant for the first time. MINI lengthened the chassis slightly to fit a second pair of doors, and the result is a small but functional back seat. It is still a MINI, so the space is a squeeze, but adults get a little more comfort in the rear than the three-door ever allowed. The extra length also improves the ride. The cost is character: the added mass and length take the edge off the sharp turn-in and go-kart feel that define the three-door, so if driving feel is the reason you are shopping, the three-door is still the purer car. What to buy: a 2016 to 2018 Cooper with a manual and a documented history for the lowest risk, or a 2021-on Cooper S or JCW with the manual for the best driver’s car of the generation. What to avoid: a 2014 or early 2015 Cooper S without full crankshaft recall documentation, any DCT car without updated software and any JCW with a long service gap and no sign of regular oil changes. The full breakdown is in our Ultimate F56 buyer’s guide, and the F56 hub collects everything else. Our F56 vs F66 JCW back-to-back shows what changed next. F66 (2024 to present): more power, one gearbox The F66 is a heavily revised F56, not a clean-sheet car, which explains why it feels eerily familiar and why the Cooper still sits on the structure that debuted in 2014. MINI pushed the headlights forward, stripped out non-functional vents and scoops, and moved to a minimal interior dominated by a round OLED display. It also made two decisions that matter to buyers: the manual is gone, and every F66 uses the seven-speed DCT, with a dash-mounted toggle replacing the gear lever. The Cooper C is the surprise. In North America it uses the same B48 as the S, tuned to 161 hp and 184 lb-ft, and it lands close to the performance of an R53 Cooper S. Our Cooper C review explains why that feels right. The problem is what MINI withheld: no paddles, and no access to the JCW Style package. The Cooper S, with 201 hp and 221 lb-ft, unlocks that package for about $1,200, adding paddles, adaptive dampers, larger brakes and the aero kit. For most buyers that combination is the sweet spot of the range, as we argued in our review of the Cooper S with JCW trim. The full JCW answers a different question. It makes 231 hp, the same as the final F56 JCW, but 280 lb-ft arrives at just 1,500 rpm, 45 lb-ft more than before and 59 more than the S. It also brings three downgrades: no manual, single-piston calipers in place of the old four-piston units, and 146 lbs of extra weight. At the Nürburgring 24 Hours the F66 JCW lapped in 10:06.773 against 10:44.118 for the outgoing F56 JCW, so the trade clearly works on a stopwatch. Whether it works for you depends on how often you actually use the torque, which is the question our Cooper S vs JCW breakdown asks. On value, the Oxford Edition remains the play. For the 2027 model year, MINI USA lists the Cooper C Oxford Edition at $25,500 for the two-door and $26,500 for the four-door, plus $1,350 destination, as covered in our Oxford Edition report. Like the F56 generation, MINI also offered a stretched version of the F66 in the form of the F56 five door. The body is stretched slightly, the rear doors are small but useful, and the back seat is a little more comfortable than in the three-door. The ride benefits from the extra length, and the turn-in is a touch less sharp because of the added mass. MINI USA sells it as the four-door, and it is the version priced in the Oxford Edition figures below. One caveat deserves honesty. The F66 has no long-term track record yet, so we cannot give you a documented list of common faults the way we can for the R56 or F56. It uses a revised version of the B48 that proved durable in the F56, which is encouraging, but encouraging is not the same as proven. The interior is also a trade: the F66 moved to textile materials as part of a deliberate design shift, coherent on its own terms but not as plush as the best F56 cabins. Our F66 hub has the rest. Cooper vs Cooper S vs JCW: the verdict by generation The gap between the trims has never been consistent. In some eras the JCW was everything, in others almost nothing. Here is how it plays out for each MINI Cooper generation. GenerationCooperCooper SJCWR50 and R53Fine, but stick to 2005 to 2006 and avoid the CVTThe one to buy; supercharger history decides everythingWorth the premium only with factory provenance and a documented supercharger serviceR56The safest R56, especially the N16N18 or keep walking; a cheap pre-LCI S is rarely a bargainMost exposure for the extra urgency; check the engine code, because 2011 and 2012 cars still have the N14F56The sensible buy, best with the manual and from 2016A properly sorted B48; avoid 2014 and early 2015 without recall paperworkEarns its premium in manual form onlyF66The Cooper C is more car than its price suggests, but no paddles; the Oxford Edition is the value playWith JCW Style, the sweet spot of the rangeRight if you will genuinely use the torque advantage over the S MINI Cooper pre-purchase checklist, by generation Whatever you are shopping for, these are the checks we would make before anything else. While this is in way exhaustive, it’s a great starting point. As always, we would recommend taking any potential purchase to an independent MINI mechanical for inspection. GenerationCheck firstWalk away ifR50 and R53Supercharger noise, nose cone seepage and rebuild history; crank seal and sensor O-ring leaks; expansion tank condition; power steering pump; sunroof drains and a dry footwell; rust under the door sills and below the rear lightsIt is an early R50 with the CVT, the footwell is damp, or there is no service historyR56The engine code first (N12, N16, N14 or N18); cold-start chain noise; valve cover leaks; suspension bushings and wheel bearings; automatic service historyIt is a cheap pre-LCI Cooper S with deferred servicing, or a “facelift” JCW that still has the N14F56Crankshaft recall paperwork on 2014 and 2015 Cooper S models; DCT software updates on 2019-on cars; oil consumption and service gaps on JCWs; upper engine mount; control arm bushings; thermostat and oil filter housingsThe recall history is vague, the DCT is not updated or a JCW has gone years without an oil changeF66That the car is the trim you think it is (the Cooper C cannot take paddles or JCW Style); whether the Oxford Edition beats a stepped-up C on equipmentYou are paying S money for a C, since we have no documented fault pattern yet and this is a spec decision rather than a mechanical one Our take: pick the generation first, then the trim Most buyers start with the badge and the budget. Start with the generation instead. A Cooper S can be the best car in this guide or the most expensive one, and which it turns out to be depends on the engine code, the build date and the paperwork long before it depends on the badge on the boot. Begin with what the car is for. If it is a daily driver you want to stop thinking about, buy an F56 Cooper from 2016 on, with the manual if you can drive one, and spend part of the savings on an independent inspection. If it is a weekend car and you want the most connected driving experience, the R53 Cooper S and the F56 Cooper S or JCW with the six-speed manual are the two answers, and they could hardly be more different. The R53 is raw, loud and demanding. The F56 is quick, durable and easy to live with. If you want a new car with a warranty, buy the F66 Cooper S, add the JCW Style package and stop there, unless you will genuinely use the extra torque of the JCW. Our Cooper S vs JCW breakdown will help you decide. Next, set the budget with ownership in mind, not just the purchase price. On the R53 and the pre-LCI R56, the cheap example is almost always the expensive one, because deferred maintenance shows up as a supercharger rebuild or a timing chain job in your first year. Hold back a repair reserve before you buy, and be prepared to walk away from a car that needs one on day one. Then choose the gearbox, because it shapes the car as much as the trim does. In every generation up to the F56 the manual is the safer and more rewarding choice, and on the F56 JCW it is the difference between a premium that makes sense and one that does not. Our ranking of every MINI transmission shows which ones to avoid. On the F66 there is no choice to make. Only then pick the trim. The Cooper is the right answer more often than enthusiasts admit, particularly the N16 R56 and the F56 B38. The Cooper S is the sweet spot of almost every generation, as long as the engine is the right one. The JCW is for the buyer who will use what it adds and can afford to maintain it. The case for the cheaper Cooper is stronger than the badge hierarchy suggests. Finally, verify before you pay. Ask for the engine code, the build date and the full service records, then use the checklist above. If a seller cannot or will not produce them, that tells you what you need to know about the car. Four generations in, the MINI Cooper story has a clear arc. MINI built its first cars on borrowed hardware, learned expensive lessons on the second, then spent a decade making the third properly. The fourth is the quickest and, without a clutch pedal, the least involving. What happens next is still undecided. BMW is consolidating its architectures, and our reporting puts the next all-new Cooper in the early 2030s with an F66 LCI in between, as we laid out in the Cooper’s future and in the story of how BMW almost killed the combustion Cooper. Until then, the F56 is the last Cooper built before the manual disappeared and the F66 is the first built without one. That gap is what you are really choosing between. MINI Cooper FAQ What is the most reliable MINI Cooper? The F56 from 2016 onward, with BMW’s own B38 and B48 engines, is the strongest all-round answer. Within the older generations, the R56 Cooper with the N16 engine is the safest of its range, and 2005 to 2006 R50 and R53 cars are the best of the first generation. Which MINI Cooper years should I avoid? Avoid early R56 cars, meaning the pre-LCI Cooper S built before the 2011 facelift with the N14 engine, unless the timing chain, high-pressure fuel pump and turbo have documented attention. The same goes for any 2011 or 2012 JCW, which still has the N14, so check the engine code rather than the model year. Also avoid a 2014 or early 2015 Cooper S without full crankshaft recall documentation, an early R50 with the CVT or the original Midlands manual, and any R53 with an unknown supercharger history. The early R56 Cooper with the N12 is a different story and is generally fine. What is the difference between the MINI Cooper, Cooper S and JCW? The Cooper is the base car, the Cooper S adds more power and, in most generations, a sportier chassis, and the JCW is the top performance trim. What each gap means changes by generation: huge on the R53, modest on the R56, tied to the manual on the F56, and mostly about torque on the F66. Is the MINI Cooper S worth it over the Cooper? On the F66 the S costs about $4,000 more for 40 hp, and it is the only way to reach the JCW Style package. On older cars the answer depends on the engine, because a neglected N14 Cooper S costs far more than the Cooper it replaced. Can you still buy a manual MINI Cooper? Not new, as of this writing. The F66 uses a seven-speed DCT across the range, and the F56, which ended production in February 2024, was the last Cooper offered with a manual. We track where that conversation stands in our look at the future of the MINI Cooper manual. Does the MINI Cooper use BMW engines? Only from the F56 (2013) on. The R50 and R53 used the Chrysler-engineered Tritec, built in Brazil, and the R56 used the Prince family co-developed with PSA. The F56 and F66 use BMW’s B38 and B48. Is there an electric MINI Cooper? Yes. Currently MINI offers the J01 Cooper E and SE. They are completely separate cars from the petrol hatch covered here and not available in markets like North America. See our J01 hub. Where can I find more MINI buying advice? Our MINI buying guides section collects every guide we have published, and our JCW section covers the performance trims in depth. The post MINI Cooper Buyer’s Guide: R50, R53, R56, F56 and F66 Compared appeared first on MotoringFile. View the full article Ссылка на комментарий Поделиться на другие сайты More sharing options...
