DimON Опубликовано March 14 Жалоба Share Опубликовано March 14 For enthusiasts who still insist on three pedals, the manual gearbox in the modern JCW hatch may be one of the most underrated parts of the car. Beneath the compact bodywork of the MINI Cooper John Cooper Works (F56) sits a transmission that is stronger and more capable than any manual MINI has offered before. That gearbox is the Getrag GS6-59BG. Built by Getrag (now part of Magna International), the GS6-59BG is a modern six-speed manual designed for high-torque turbocharged engines. And it quietly represents the strongest manual drivetrain MINI has ever paired with a production car. Despite this MINI sadly only used the GS6-59BG in two cars; the F56 JCW and F57 JCW. Why not more and could MINI ever have used it in the 302 HP JCW GP? After digging through the technical details, we found some surprising answers. The 1to6 – MINI’s last manual JCW ever. Inside the GS6-59BG – MINI’s best & Last Manual First let’s decode Getrag’s naming structure. If you’re a nerd like us, you’ll love this: • GS refers to a synchronized manual gearbox.• 6 denotes six forward gears.• 59 represents the gearbox’s torque class. The first thing that might jump out at you is that 59 torque class. What that means is that this transmission is designed for up to about 590 Nm or 435 lb-ft of torque. Yup… a lot of torque. In the JCW, the turbocharged B48 engine produces 320 Nm or 236 lb-ft of torque. That means the transmission is operating well below its theoretical limit, leaving a considerable margin of durability and tuning headroom. But more on that in a moment. B172S12B1 Since the beginning Getrag has produced manuals for the Cooper S and the JCW. How It Differs From Earlier MINI Gearboxes Earlier MINIs used lighter-duty manual transmissions because the engines produced far less torque. The supercharged Mini Cooper S (R53) used a six-speed Getrag manual paired with about 162 lb-ft of torque. It delivered short throws and a very mechanical feel, but it was not designed for high torque loads. The turbocharged Mini Cooper S (R56) moved to a revised six-speed Getrag that offered a slightly more fluid feel when shifting. The gearbox became slightly heavier and more robust as well. The GS6-59BG in the F56 generation represented major step forward in component quality and torque capabilities. Compared with those earlier transmissions it has: • Stronger internal gears and shafts• Heavier clutch engagement for higher torque loads• Smoother synchronizers• Slightly longer throws (which theoretically supports durability due to the design) In hand the GS6-59BG feels easier to interact with than earlier MINI gearboxes, but it is also far stronger. While some may miss the notch-like action of the R53’s Getrag, it can’t come close to the slick shifting ability that MINI introduced with the F56 JCW. A Manual F56 GP3 Was Possible After all! The limited-run GP 3 (F56) produced over 300 horsepower and 331 lb-ft of torque, yet it was offered exclusively with an automatic transmission. At the time, the prevailing rumor was that the torque was too much for the Getrag manual to handle. But looking at the specs of the Getrag GS6-59BG, that explanation doesn’t really hold up. With a torque class approaching 590 Nm (about 435 lb-ft), the gearbox used in the F56 JCW clearly had the theoretical capacity to handle the GP3’s output. In other words, a manual GP3 was technically very possible. So why the automatic? Thinking back to conversations we had with the car’s program lead, one comment now stands out more than ever. Managing that much torque through the front wheels without creating overwhelming torque steer was one of the biggest engineering challenges MINI faced with the GP3. A significant amount of development went into the car’s stability and traction control systems to keep the power usable. Those systems were tightly integrated with the automatic transmission. It is likely MINI simply concluded that pairing the GP’s torque with a manual gearbox would make the car too unruly for most owners. The automatic allowed engineers to precisely manage power delivery and keep the car controllable under hard acceleration. Still, it leaves us with one of the bigger “what ifs” in modern MINI history. Yes, a manual GP3 probably would have been a handful. But channeling 331 lb-ft of torque through the front tires with three pedals would almost certainly have made the car feel more alive and engaging. And for some enthusiasts, that is exactly what the GP3 was missing. Is This the Same Transmission as the F56 Cooper S? Yes, with an important nuance. The Mini Cooper S (F56) manual uses the same GS6-59 family gearbox, but with slightly different clutch calibration depending on model year and market. In simple terms the transmission architecture is the same. However the JCW version is calibrated to handle more torque and a heavier clutch load. So while the Cooper S and JCW manuals are closely related, the JCW setup is tuned for the higher output of the B48 engine. The Long Goodbye for MINI’s Best manual When was the last time you could look at a major component in a modern car and know it was massively overengineered for the job? That is exactly what the GS6-59BG feels like. As expected, it has proven extremely durable not only in stock form but also in heavily tuned cars pushing far beyond factory power levels. The GS6-59BG may not have the rifle-bolt precision of the legendary six-speed in the MINI Cooper S (R53), and it certainly does not deliver the short, mechanical throws you would find in something like a BMW M2 or a Porsche 718 Cayman. But in terms of pure engineering capability, it is easily the most robust manual transmission MINI has ever installed in a production car. Yet celebrating this gearbox also inevitably leads to a few lingering “what ifs.” What if MINI had paired it with the GP3? And perhaps the biggest one of all: what if MINI had carried it forward into the current MINI Cooper (F66)? Instead, the GS6-59BG quietly represents the end of an era. The strongest manual MINI ever built has also become the last. The post The Best MINI Manual Ever? A Deep Dive Into the F56 JCW’s Surprising Getrag 6-Speed appeared first on MotoringFile. View the full article Ссылка на комментарий Поделиться на другие сайты More sharing options...
