The Complete Guide to MINI Cooper Transmissions – Every Gearbox Ranked (2001–Today)
Since BMW relaunched the MINI Cooper in 2001, the brand has used a surprisingly wide range of MINI Cooper transmissions. Some became central to the MINI driving experience while others quickly developed reputations enthusiasts would rather forget. And if you own or are shopping for a modern MINI, knowing which gearbox sits under the hood matters more than you might think.
From the infamous early CVT automatic to the massively over-engineered Getrag GS6-59BG manual, MINI’s transmission history mirrors the evolution of the brand itself. Over the past two decades MINI has used everything from Rover-era manuals and Aisin torque-converter automatics to modern dual-clutch gearboxes and some of the most capable MINI manual transmissions ever fitted to a small performance car.
Below is a complete guide to every major MINI Cooper transmission since 2001, ranked from worst to best based on reliability, engineering sophistication and, most importantly, how they feel behind the wheel.
MINI Cooper Transmission Quick Guide
First let’s give you the high-level. For a car that’s only been around for 25 years, the new MINI has had quite a few different transmissions offered. Which means knowing you have or might purchase can be quite important.
TransmissionTypeManufacturerUsed InYears
ZF VT1FCVTZFR50 Cooper2002–2006
Midlands GS5-65BH5-speed manualMidlandsR50 Cooper2002–2004
Getrag GS5-52BG5-speed manualGetragR50 LCI Cooper2004–2006
Getrag GS6-85BG6-speed manualGetragR53 Cooper S2002–2006
Getrag GS6-53BG / GS6-55BG / GS6-53DG6-speed manualGetragR50, R53, R52, R55, R56, R57 R58, R59, R60, R612007–2015
Aisin GA6F21WA 6-speed automaticAisinR50, R53, R52, R55, R56, R57 R58, R59, R60, R612005-2015
Aisin BG66-speed manualAisinF54/F60 JCW2017–2019
Getrag GS6-59SG6-speed manualGetragF56/F55/F57 One & Cooper2015-2024
Getrag GS6-59BG6-speed manualGetragF56/F55/F57 S & JCW2015-2024
Aisin GA8F22AW8-speed automaticAisinF54/F60 Cooper & Cooper S2015–2024
Aisin GA8G45AW8-speed automaticAisinF54/F60 JCW2019–2024
Getrag 7DCT3007-speed DCTGetrag / MagnaF56/F55/F57 / F65/F66/F67/U252018–present
Where we do not note specific models, the transmission was used across the range.
Now let’s get down to business with the ranking and what to watch for in each.
Ranking Every MINI Transmission (Worst to Best)
R50_R53_0001.jpg?resize=798%2C532&ssl=1
12. ZF VT1F | CVT (2002-2008)
The transmission that almost everyone agrees belongs at the bottom. The ZF VT1F continuously variable transmission was offered on early R50 Coopers and quickly developed a reputation for poor durability. The belt-driven pulley system struggled with heat and torque loads, leading to widespread failures.
Beyond reliability concerns, the CVT also removed the mechanical feel that defined the MINI driving experience.
Model Used InManufacturerTypeYears
R50, R52 CooperZFCVT (VT1F)2002–2008
11. Midlands GS5-65BH | 5-Speed Manual (2002 – 2004)
Early base Coopers used a Midlands five-speed manual, a carryover from the Rover era. While serviceable, the gearbox lacked the crisp engagement expected from a BMW-developed product. Durability issues and vague shift feel meant MINI replaced it during the 2004 refresh.
Early R50 CooperMidlands5-speed manual2002–2004
R60_Countryman_Parklane_78_highRes.jpg?r
The distinctive racing helmet gear lever of the Aisin GA6F21WA
10. Aisin GA6F21WA 6-Speed Automatic (2005 – 2017)
The second-generation MINI introduced a modern automatic transmission manufactured by Aisin. The first conventional automatic offered in modern MINIs replaced the CVT. It proved far more reliable but was tuned primarily for smoothness rather than performance. Compared with modern gearboxes it feels slow and dull. Commonly referred to simply as the Aisin 6-speed automatic, the specific model code is GA6F21WA and it was MINI’s first transmission used across the entire model range.
In normal mode is traded quickness for smoothness giving most automatic buyers exactly what they were looking for. But most importantly it’s proven relatively reliable.
It featured MINI’s Steptronic manual mode, allowing drivers to manually select gears using the shifter or optional steering-wheel paddles. But be warned it could be become quickly confused when used manually and would be anything but smooth in sport mode.
It’s worth noting that the R56 version is considered an updated or “upgraded” version of the original. It uses the same overall Aisin TF-60SN architecture but features internal refinements to the valve body and solenoids. Another important point. The All4 version in the Countryman and Aceman was slightly different in that is offered a Power Take-Off Unit and had different mounting points. Otherwise it was identical.
R53 Cooper SAisinGA6F21WA 6-speed automatic2005-2006
R55, R56, R57, R58, R59, R60, R61AisinGA6F21WA 6-speed automatic2007–2015
F55, F56, F57, F60AisinGA6F21WA 6-speed automatic2013-2018
9. Aisin GA8F22AW | 8-Speed Automatic (2019 – 2024)
The GA8F22AW is the standard version of Aisin’s 8-speed automatic used in the larger MINI models. Rated for 350 Nm (258 lb-ft), it was fitted to the F54 Clubman and F60 Countryman in Cooper S and ALL4 form.
Compared with MINI’s earlier 6-speed automatics, the GA8F22AW brought quicker shifts, improved efficiency and a broader spread of ratios. While not as aggressive or high-capacity as the GA8G45AW used in JCW models and the GP3, it remains one of the most capable and reliable traditional torque-converter automatics MINI has offered.
F54 Clubman Cooper S / ALL4AisinGA8F22AW 8-speed automatic2019–2024
F60 Countryman Cooper S / ALL4AisinGA8F22AW 8-speed automatic2019–2024
8. Aisin BG6 | 6-Speed Manual (2017 – 2019)
When MINI launched JCW versions of the larger Clubman and Countryman, the standard gearbox was not a Getrag but the Aisin BG6. MINI went this direction due to the packaging of the ALL4 AWD system. While durable, it lacked the crisp engagement and interaction of MINI’s Getrag manual gearboxes and is beaten here by its automatic counterpart because of it. The reality is that it’s still engaging and rare enough to be sought out. Just know you’re not getting Getrag levels of interaction.
It only lasted of for a few years of the model run due to it not being able to handle the 331 ft lbs that the upgraded F54 and F60 JCWs offered from 2019 onward.
F54 JCWAisinBG6 6-speed manual2017–2019
F60 JCWAisinBG6 6-speed manual2017–2019
7. Aisin GA8G45AW | High-Torque 8-Speed (2018 – 2024)
The GA8G45AW is the high-torque version of Aisin’s 8-speed automatic. Rated for 450 Nm (332 lb-ft), it was used in MINI’s most powerful models, including the 302 hp JCW Countryman and the F56 GP3. Shifts are crisp and at times neck-snapping however its inherent downside is a lack of smoothness in some scenarios.
F54 & F60 JCW (302 hp)AisinGA8G45AW 8-speed automatic2020–2024
F56 JCW GP3AisinGA8G45AW 8-speed automatic2020–2023
6. Getrag GS5-52BG | 5-Speed Manual (2004 – 2007)
As part of the 2004 lifecycle refresh, MINI replaced the Midlands gearbox with a Getrag five-speed manual. The improvement was dramatic. Shift feel became tighter and reliability improved significantly. It shared the deliberate action of its six speed sibling in the R53 which made quick shifting a little less quick. But it’s positive action and click from gear to gear is very rewarding.
Model Used InManufacturerTypeYears in Production
MINI Cooper (R50)Getrag5-Speed Manual2004–2006
MINI Cooper (R57)Getrag5-Speed Manual2004–2007
5. Getrag 7DCT300 / 7DCT300TU / 7DCT400 | Dual-Clutch (2018 – Present)
Introduced during the later F56 lifecycle, the 7DCT300 dual-clutch transmission instantly became MINI’s most modern automatic. It delivered rapid shifts, improved efficiency and far better seamless shifts. While it doesn’t quite match the aggressive shift qualities that the Aisin GA8G45AW High-Torque 8-Speed offered, it combines shift speed with smoothness in ways no auto ever had. Because of this, it’s our pick of the autos in this list.
MINI used a slightly revised version (known as the 7DCT300TU) in the F65, F66 and F67 generation. The JCW models (F66, F67 and U25 Countryman) get the 7DCT400, a slightly more robust version designed to handle higher torque loads. Combined with updated software these transmissions slightly decreased shift times in some scenarios. While the jury is still out in terms of reliability, Getrag has a history of fairly robust transmissions and we’d expect this to be similar.
F56/F55/F57Getrag / Magna7-speed DCT (7DCT300)2018–present
F65/F66/F67Getrag / Magna7-speed DCT (7DCT300TU)2024–present
U25 CountrymanGetrag / Magna7-speed DCT (7DCT400)2024–present
4. Getrag GS6-59SG | 6-Speed Manual (2015 – 2024)
The GS6-59SG is the standard manual used in modern MINI Cooper and One models. Smooth, durable and easy to live with, it represents MINI’s most refined manual outside the Getrag GS6-59BG used in the Cooper S and JCW of the same generation. It’s ultra smooth compared with the first MINI manuals prompting some of complain of a lack of mechanical feel. But this was a conscious design decision made by Getrag and the result is that it’s excellent for day to day driving.
F56/F55/F57 One & CooperGetragGS6-59SG 6-speed manual2015–2024
3. Getrag GS6-85BG | 6-Speed Manual (2002 & 2006)
Let’s be clear, the final three could go in just about any order. Ask us on another day and we might have another answer. But today the transmission that some will hold up as MINI’s best, comes in 3rd.
The R53 Cooper S gearbox helped define the modern MINI driving experience. Short throws and crisp engagement made it one of the most enjoyable gearboxes MINI ever offered. However we’re not ranking it as high as some might assume for a few reasons. For one the shifts were less fluid than later Getrag manuals slowing engagement down. While that notchy quality may feel good every so often, it wasn’t ideal for commuting (even if we did I did it for years). Add to that a clutch engagement that felt slightly at odds with the effort the transmission required and it drops just a bit for us in the ranking.
But make no mistake, this transmission is a joy to use and one that helps to define the incredible R53 driving experience.
One note – MINI revised the gear rations for this transmission in 2004 but the transmission retained the same name.
R53 Cooper SGetrag GS6-85BG6-speed manual2002–2006
2. Getrag GS6-53BG/GS6-55BG/GS6-53DG | 6-Speed Manual (2007 – 2015)
If we were ranking transmissions according to how many cars it ended up in, the GS6-53BG might come out on top.
With the introduction of turbocharging, MINIs required a stronger manual gearbox. Enter the Getrag GS6-53BG. It was a smoother shifting transmission than what we had in the R53 but still offered some of that mechanical positivity when slotting into gear. For most, it was a big improvement for acceleration and smoother day-to-day operation. Ultimately, it was successful because it delivered improved durability while maintaining the engaging feel MINI drivers expected.
While we’re counting this as a single transmission, MINI actually had three versions. The GS6-55BG was used in the One and Cooper models where the GS6-53BG was standard o the Cooper S and JCW models. Finally for All4 Countryman and Paceman models MINI used the GS6-53DG – the “DG” version features a specific mounting point and output for the Power Take-Off (PTO) unit (transfer case) that sends power to the rear wheels. While this generation of MINIs has had reliability issues, the Getrag manual has been bulletproof for the most part.
R56, R57, R58, R59, R60, R61 – One & Cooper Getrag GS6-55BG6-speed manual2007–2013
R56, R57, R58, R59, R60, R61 – Cooper S & JCW
Getrag GS6-53BG6-speed manual2009–2013
R60 & R61 – All4 Cooper, Cooper S & JCW
Getrag GS6-53DG
6-speed manual2010-2015
1. Getrag GS6-59BG | 6-Speed Manual (2015 – 2024)
At the top sits the Getrag GS6-59BG, the most capable manual gearbox MINI has ever offered. There are some that say it lacks the mechanical feel of the R53 or even the R56. But for us this deliberate design decision allows is to be both quicker shifting and easier to daily rush those manuals. But perhaps one of the best parts about it is just how over-engineered it is.
This transmission is rated for approximately 590 Nm (435 lb-ft) of torque, yet in the F56 JCW it only handles 236 lb-ft. That enormous engineering headroom explains its excellent durability and why it has become a favorite among tuned MINI owners.
F56/F55/F57 Cooper S & JCWGetragGS6-59BG 6-speed manual2015–2024
Note: There’s a lot off data here so if we missed something, drop us a note.
The post The Complete Guide to MINI Cooper Transmissions – Every Gearbox Ranked (2001–Today) appeared first on MotoringFile.
