DimON Опубликовано October 22, 2025 Жалоба Share Опубликовано October 22, 2025 You only really get to know a car at its limit. With the Countryman JCW, that limit usually lives somewhere beyond reach — buried under layers of grip, all-wheel drive confidence, and tire tech that makes mistakes hard to find. Unless, of course, you leave the road behind. So we did. East out of Bozeman, Montana, where the pavement gives way to gravel and the hills start to rise into mountains. The goal wasn’t speed, or even precision. It was something simpler — to see how MINI’s biggest performer behaves when the asphalt ends and the world turns to dust. The Journey Begins Our route began on Bridger Canyon Road, carving through long sweepers and rolling elevation changes framed by the Bridger Mountains. From there, Jackson Creek Road tightened the rhythm — a narrow, technical stretch of tarmac that brought the chassis to life. It’s the kind of road that should reward a Cooper much more than a Countryman. Yet the rigidity, suspension calibration and quick steering masked the weight of the Countryman JCW more than I would have expected. While it lacked the texture you might feel through the wheel of an R53, it felt dialed in, communicating more than enough to give me plenty of confidence. A quick hop onto I-90 set us up for Trail Creek Road, where we soon peeled off onto a series of narrow, climbing dirt routes — the kind that snake up the mountainside toward 7,000 feet and demand both grip and composure. Here, the real test began. The surface shifted constantly between loose gravel and hard-packed clay, challenging the JCW to find its footing. With Go-Kart Mode engaged, the JCW allowed just enough slip to make things fast, flowing, and interesting. However, this is where we came face to face with its biggest limitation: summer tires. The Pirelli P Zeros are excellent performers on pavement above 45 degrees, but on dirt, they’re less than ideal. But a funny thing happens when you have limited grip — you really get to know a car. What became immediately clear was how easy the Countryman’s reactions were to predict. Once the tires began to slide, the JCW settled into a natural rhythm — confident, balanced, and surprisingly communicative for a crossover on summer rubber. MINI’s all-wheel-drive system quietly did its part, managing power with just enough slip to keep things playful without ever losing control. Back on Trail Creek and tarmac, I pushed on into a series of flowing corners — exactly the kind of terrain the JCW typically loves. And then it appeared: the Absaroka Mountains and Paradise Valley stretching wide ahead. If you’re a fan of Yellowstone, it’s worth noting that this is the very landscape that inspired the Dutton family’s fictional ranch — and the fight to preserve it that made the show’s early seasons so compelling. But out here, the real world easily outshines the scripted one. Paradise Valley doesn’t just live up to its name — it exceeds it. Every switchback was more magical than the last, winding through sweeping turns and gradual descents as Paradise Valley opened ahead. As the road unwound and the elevation dropped, speeds climbed. The curves widened, dust plumed behind, and the JCW’s massive brakes were only limited by the tire’s traction. Which, if I’m honest, was not stellar. Finally, we reached US 89. Turn right, and you’re bound for Yellowstone – the real one. Turn left, and the road drops into Livingston, one of the West’s most authentic small towns, part cowboy, part artist enclave, and a perfect place to end a day of backroad exploration. We turned left. Final Thoughts As impressive as the JCW’s balance is on performance tires, one thing becomes immediately clear: a more aggressive all-terrain setup would transform this experience. The chassis and suspension have the control to handle it — the only limiting factor is traction. Fortunately, sources tell us MINI is developing exactly that: an all-terrain package for the Countryman that could include revised tires and subtle off-road tweaks. If those rumors hold true, it might just unlock the Countryman’s full potential as a genuine all-surface performance crossover. In its current form, though, the JCW proves something essential about MINI’s DNA. You don’t need perfect pavement to enjoy it — just a good road, even one made of dust, gravel, and the occasional washboard, and a willingness to let the car move beneath you. On the backroads of Montana, that’s exactly what makes the drive unforgettable. The post MINI Countryman JCW Review: The Montana Dirt-Road Test appeared first on MotoringFile. View the full article Ссылка на комментарий Поделиться на другие сайты More sharing options...
