MINI Aceman Deep Dive: Specs, Performance & How It Fits into MINI’s Future
DimON
 Share
MINI’s recent history has been full of evolution. Since the BMW-engineered rebirth in the early 2000s, the brand has continuously evolved to stay relevant with various Cooper models and Clubman and its best selling Countryman. Now, with the MINI Aceman, we might be looking at one of the most significant steps in its recent history—a crossover that straddles the line between the classic MINI ethos and the electric future.
But what exactly is the Aceman? And how does it stack up in terms of specs? We recently looked at how it fits into the line-up and compares with its siblings, now let’s take a deep dive into its technical details, comparing the E, SE, and the high-performance John Cooper Works (JCW) version.
J05_268-highRes.jpg?resize=798%2C532&ssl
The Basics: MINI Aceman at a Glance
Unsurprisingly all three variants—the Aceman E, Aceman SE, and JCW Aceman share the same overall dimensions. But it’s how they stack up to the other four door MINIs that’s interesting.
ModelsJ05 AcemanF65 MINI Cooper 5 DoorU25 Countryman (’24-’32)
Length4079 mm / 161 in4,036 mm (158.9 in)4429 mm / 174.37 in
Height1514 mm / 59.6 in1,464 mm (57.6 in)1613 mm / 63.5 in
Wheelbase2526 mm / 99.44 in2,567 mm (101.1 in)2670 mm / 105.11 in
Cargo Volume300 liters (10.6 cu ft)275 liters (9.7 cu ft)705 liters (24.9 cu ft)
Cargo Volume (seats down)1,005 liters (35.5 cu ft)925 liters (32.7 cu ft)(1,588 liters) 56.1 cu ft
The Aceman is a crucial bridge between the traditional MINI Cooper hatchback and the larger MINI Countryman. It’s targeting drivers who want the go-kart feel but need more space—all without going full SUV.
J05_F65_249-highRes.jpg?resize=798%2C532
The Countryman wins out in cargo capacity due to its larger size. However it’s the similarity with the F65 MINI Cooper five-door that should be noted. The F65 was introduced as a refresh of its predecessor, measures 4,036 mm in length, 1,744 mm in width, and 1,464 mm in height. These dimensions provided a compact yet practical hatchback option – especially for those in urban settings. On the other hand, the J05 MINI Aceman, MINI’s foray into the electric crossover segment, measures 4,079 mm in length, 1,754 mm in width, and 1,514 mm in height. This makes the Aceman slightly longer (+43 mm) and taller (+50 mm) while being fractionally wider (+10 mm), than the F65. In other words it’s a crossover version of the same concept.
They also all feature a single-speed automatic transmission and all models are exclusively front-wheel drive. Why no real wheel drive? The Aceman is built on the same platform as the J01 Cooper and thus was never engineered to have dual motor set-up, a necessity for an all wheel drive EV.
Now, let’s break down what sets them apart.
J05_SE_161-1.jpg?resize=798%2C532&ssl=1
The Aceman E
MINI Aceman E: The Entry-Level Electric Crossover
If the Aceman lineup were a rock band, the E would be the smooth baseline—foundational, steady, and dependable.
Performance & PowertrainSpecification
Motor Output184 hp (135 kW)
Torque290 Nm
0-100 km/h7.9 seconds
Top Speed160 km/h
While not the quickest, the Aceman E offers a balanced power-to-weight ratio (12.2 kg/kW) and an instant torque delivery, making it feel zippy in the city.
Battery & ChargingSpecification
Battery Size42.5 kWh (gross), 38.5 kWh (net)
Range (WLTP)Up to 309 km
AC Charging Time7.4 kW AC: 6.75 hours (0-100%)
DC Charging Time70 kW DC: 28 minutes (10-80%)
With modest range and charging speeds, the E is clearly designed for urban commuting rather than long-haul adventures.
J05_77939_highRes_mini-aceman.jpg?resize
The Aceman SE
MINI Aceman SE: More Power, More Range
The SE is the middle ground—offering a noticeable performance boost over the E while improving range.
Motor Output218 hp (160 kW)
Torque330 Nm
0-100 km/h7.1 seconds
Top Speed170 km/h
This SE is noticeably quicker, especially with 30% more torque than the base model. While the 0-60 still doesn’t crack into the 6 second range, it’s increase in torque makes it feel much more responsive.
Battery Size54.2 kWh (gross), 49.2 kWh (net)
Range (WLTP)Up to 405 km
AC Charging Time7.4 kW AC: 9 hours (0-100%)
DC Charging Time95 kW DC: 31 minutes (10-80%)
The SE’s larger battery and 95 kW fast-charging capability make it a better choice for road trips, giving it 96 km more range than the E. This will especially help in colder weather environments where batteries can lose almost 30% of range.
JCW_J05_53.jpg?resize=798%2C532&ssl=1
The Aceman JCW
MINI John Cooper Works Aceman: The Performance EV
For those who want a MINI with extra spice, the John Cooper Works Aceman delivers.
Motor Output258 hp (190 kW)
Torque350 Nm
0-100 km/h6.4 seconds
Top Speed200 km/h
Let’s get this out of the way – this is a true hot crossover despite being front wheel drive. While 6.4 second isn’t a blistering 0-60 time in 2025, it’s suspension tuning and overall feel create an engaging driving experience that few rivals offer. While some will callout the FWD layout as limiting, it helps reduce weight (it’s already 3,935 lbs) and helps with range.
Range (WLTP)Up to 355 km
AC Charging Time11 kW AC: 5.5 hours (0-100%)
Speaking of range, it’s down slightly to the SE but it seems like a fair trade-off for the increase in performance.
J05_276-highRes.jpg?resize=798%2C532&ssl
The Aceman SE with the JCW Trim
MotoringFile’s Take
With all of that said, there are some clear positives and negatives to the MINI Aceman.
Strengths– Crossover more aligned to consumer desires than the Clubman
– More Interior Space than a 5-Door Cooper despite being relatively the same size
– Instant Torque makes it feel responsive Fast-Charging Support (SE & JCW)
Potential Weaknesses– Front-Wheel Drive Only (No AWD)
– Not a True Hot Hatch (JCW could use dual motors)
– Relatively Modest Range (Competitors push 450-500 km)
The MINI Aceman marks a shift for the brand, slotting between the Cooper and Countryman as an all-electric crossover aimed at urban drivers. It keeps MINI’s signature compact proportions but adds more space and tech, leaning heavily into a futuristic design language. Whether it resonates with consumers is another question.
J05 MINI Aceman EJ05 MINI Cooper SE2025 J05 Aceman JCW
Horsepower184 hp218 hp258 hp
Torque214 lb-ft243 lb-ft252 lb-ft
Range (WLTP)183 – 193 miles237 – 253 miles221 miles
Battery Size40kWh54kWh54kWh
J05_277-highRes.jpg?resize=798%2C532&ssl
The lack of all-wheel drive might limit its appeal in some markets, and while MINI claims it retains the brand’s trademark agility, there’s plenty of rivals that offer it.
It’s also worth noting that the Aceman won’t be available in North America anytime soon, and some markets—like Australia and New Zealand—are only getting limited models. MINI is betting big on an electric future, but with availability restricted, the question isn’t just whether people will want it—it’s whether they’ll even get the chance to buy it.
Still we think the Aceman is an important step for the brand. MINI is straddling the line with the classic small hatch formula and the crossover layout that so many people are looking for. To us, it would appear that the Aceman does this quite well.
MINI Aceman Photo Gallery
The post MINI Aceman Deep Dive: Specs, Performance & How It Fits into MINI’s Future appeared first on MotoringFile.
Link to comment
Share on other sites
 Share
