The Electric MINI Countryman SE Range and Charging Details
The electric Countryman SE is MINI’s first electric vehicle for the majority of consumers. It combines electrification in the crossover packaging that so many are looking for. More importantly its range is high enough for global mass market appeal. But it’s more than range that matters in an electric car. Charging speed, battery capacity and cold weather performance all are crucial. Let’s take a deep dive into all of it.
In the UK that range is listed as 245 to 287 miles depending on how much urban vs highway driving you’re doing. In the US that is estimated to be to be a 245 mile EPA range. With either set of numbers it’s clear that the Countryman SE will be much more viable of a choice than the first generation Cooper SE with it’s 110 mile range (EPA).
mini countryman
The battery capacity in the electric MINI Countryman is 66.5 kWh with the usable size being 63.78 kWh. The 400v system allows an AC charging speed of 11kW and DC – 130kW. In ideal scenarios (charging at 130kWx) the electric Countryman SE can get from 5-80% in only 29min. In miles that’s roughly 23 to 184 miles in normal operating temperatures. While we didn’t need to charge our test car (our time was limited to a few hundred miles) that type of charging speed sounds fantastic. However the ability to recharge the Countryman SE quickly will be more dependent on the charging network than the car itself.
Mild Weather ScenariosRange Estimates
City – Mild Weather *535 km / 332 miles
Highway – Mild Weather *340 km / 211 miles
Combined – Mild Weather *420 km / 261 miles
Cold Weather ScenariosRange Estimates
City – Cold Weather *360 km / 224 miles
Highway – Cold Weather *265 km / 165 miles
Combined – Cold Weather *310 km / 192 miles
Indication of real-world range in several situations. Cold weather: ‘worst-case’ based on -10°C and use of heating. Mild weather: ‘best-case’ based on 23°C and no use of A/C. For ‘Highway’ figures a constant speed of 110 km/h is assumed. The actual range will depend on speed, style of driving, weather and route conditions. Data provided by ev-database.org
iX1_U25.jpg?resize=798%2C532&ssl=1
While this is the BMW iX1, it’s has an identical battery and electric engine to the Countryman SE
2025 MINI Countryman Electric Charging Speed
Charging speed is as critical if not more so than range depending on your situation. The electric Countryman SE supports DC fast-charging at up to 130 kW. This allows for a charge from 10 percent to 80 percent in only 29 minutes. While we don’t have US specific data, we do have European data on charging speeds which should give you an idea of what we’ll see with the electric MINI Countryman SE.
Charging PointMax. PowerPowerTimeRate
Standard 11.0 kW On-Board Charger
Wall Plug (2.3 kW)230V / 1x10A2.3 kW33h15m11 km/h
1-phase 16A (3.7 kW)230V / 1x16A3.7 kW20h45m18 km/h
1-phase 32A (7.4 kW)230V / 1x32A7.4 kW10h30m35 km/h
3-phase 16A (11 kW)400V / 3x16A11 kW7 hours53 km/h
3-phase 32A (22 kW)400V / 3x16A11 kW †7 hours53 km/h
Optional 22.0kW On-Board Charger *
3-phase 32A (22 kW)400V / 3x32A22 kW †3h30m100 km/h
* = Optional in some countries, standard in others. Check local specifications for details.
† = Limited by on-board charger, vehicle cannot charge faster.
mini countryman
MotoringFile’s Take
As with all electric cars you have to ask yourself – will this new electric Countryman fit my lifestyle. With the original Cooper SE that was a tough sell for anyone looking to take even short road trips. But with the new electric MINI Countryman SE the equation has changed.
The range dramatically increases the use cases for this car over the Cooper SE and thus its appeal. But that doesn’t mean everything here is cutting edge. In many ways the Countryman’s EV underpinnings are appropriately middle of the pack. Proven tech with conservative ratings, it’s designed and engineered to last. And given the needs of consumers that might be a better fit for the typical Countryman SE buyer.
The post The Electric MINI Countryman SE Range and Charging Details appeared first on MotoringFile.
