Review: Electric MINI Countryman SE – The Range & Performance We’ve Been Waiting for
Finally MINI is launching a fully electric car that’s meant for the masses with plenty of range of huge power figures. But how do these figures from the electric Countryman SE translate into the real world and how could a 4,574 lbs car feel like a MINI? We went to Portugal to speak to the people behind the car and get behind the wheel.
Stepping into the new electric Countryman SE is a vastly different experience than any MINI before it. The new interior layout does away with the cluster display behind the steering wheel as all relevant content is projected onto circular display and the head-up display (standard in the US). Reduced to the essentials, the new interior has a much different, more relaxing feel to it.
electric MINI Countryman SE
The there’s the size. Like the new Countryman JCW we reviewed a couple of weeks ago, the SE is built on a new, larger platform (code named U25) which has allowed the it grow in every dimension. While the increase isn’t has big as it was with the previous generation Countryman over its predecessor, it’s still a noticeable change. That’s evident in the interior immediately. The driver and front passenger have almost three centimeters of additional width at the shoulder. Similarly the rear passengers have 2.5 centimes of extra weight thanks to a wider track and better use of space in general.
But the real change is the moment you twist the “key”. The electric MINI Countryman SE registers this action with a subtle hum and visual welcome. From there your hand intuitively moves over to the gear toggle where you pull down for “D” and head out.
The Driving Experience of the Electric MINI Countryman SE
We had the chance to drive the petrol Countryman JCW and electric Countryman SE back to back and came away with some surprising conclusions. First off do not let the identical power figures fool you. The JCW is tuning (from its brakes to its suspension) to be much more performance oriented. The electric Countryman SE was nearly as quick but never felt as light on its feet or as eager. That’s likely due to two things. The most obvious is the fact the SE weighs 886 lbs more than the JCW.
The second is how MINI has tuned the suspension and steering. Not surprisingly MINI has designed and engineered the SE as a daily driver that delivers comfort and performance vs the JCW which flips that script. Yes it’s quick and has plenty of torque – all 364 ft lbs are available almost immediately. The moment you push the car in corners you realize that this is not a JCW.
U25_Countryman_014.jpg?resize=798%2C532&
The benefit of that is obvious. This is a fantastic daily driver that never punishes you. Instead it rewards with plenty of performance an and likely the most comfortable MINI never. The SE absorbs road imperfections and drowns the noise associated with them so well it’s almost un-mini-like.
The downside hits when you’re hustling it. Going from corner to corner along the Portugal coast give me some impression of weight. But as I got more confident with the grip levels (and away from the cliffs) I could explore the limits further. What I found was a car that felt incredibly competent until you hit 8/10s. That’s when the weight penalty was exposed and the car began to understeering. Not that this is a surprise of course. MINI has done an admirable job hiding the extra 886 lbs over the JCW version but that doesn’t mean its not there.
What is here is a quick, compliant Countryman that oozes torque and accelerates effortlessly. The combination makes the Countryman SE likely the best daily driving MINI we’ve ever tested.
MINI engineers have focused on being more holistic in the tuning of key components from axles, steering and dampers. This is combined with more sophisticated processors controlling the dynamic control systems and a more direct steering rack ratio of 55 mm of rack travel per turn creates a more fluid and reactive driving experience.
The Electric MINI Countryman – A Symphony of Sound
The silence is golden. No matter how many electric cars we drive we never get tired of the serenity of an EV. But that silence doesn’t last, Like BMWs, MINI has created its own sound language thats intended to provide feedback and even a touch of excitement during spirited drives. So they told us. But hearing would be believing.
Pushing the Countryman SE through the mountains and coastal roads of Portugal was itself a blast. But the sound effects that came with the acceleration was a genuinely fun part of the experience. You definitely need to not take things too seriously to enjoy them. But once you embrace the new world of EV performance the added sound effects that MINI has created really do make sense.
They’re also just fun. Imagine a real-life Mario Kart video game and you get the idea. It’s surprisingly engaging and becomes a real part of the driving experience. And yes, we know this sounds insane. But we heard more than one very jaded automotive journalist on the launch giggle when recounting the interior sounds the Countryman SE was producing during spirited driving.
However key to all of these sounds is the ability to turn them off. Yes it is possible. Even the “experience jingles” that play when you change the experience mode can be switched off permanently.
The New Countryman JCW Is The Biggest MINI Ever
The new Countryman is big but according to MINI designers and engineers that’s due to customer feedback. MINI has been losing costumers as families or space needs grow. The solution to this was to carefully grow the Countryman taking the majority of the BMW X1’s chassis and the rear portion of the European BMW 2 Series Active Tourer.
R60 Countryman JCW (’10-’16) F60 Countryman JCW (’17-’23)U25 Countryman JCW (’24-’30+)U25 Countryman SE (’24-’30+)
Length4097 mm / 161.3 in4298 mm / 169.2 in4429 mm / 174.37 in4429 mm / 174.37 in
Height1562 mm / 61.5 in1557 mm / 61.3 in1613 mm / 63.5 in1613 mm / 63.5 in
Wheelbase2596 mm / 102.2 in2670 mm / 105.1 in2670 mm / 105.11 in2670 mm / 105.11 in
Weight3,307 lbs3,688 lbs 3,825 lbs4,574 lbs
So what does the increase in size get you? There’s more legroom in the front and back along with 25 cu-ft more luggage capacity with the seats up. That grows to over from 47.6 cu-ft to 56 with the seats folded down. This gives the new Countryman class leading space in the subcompact luxury crossover segment.
The rear of the new Countryman offers more space than we’ve ever seen in a MINI. But more impressively there’s more options as well. The position of the rear row of seats can be adjusted in length by up to 13 centimeters providing more legroom at the rear or additional volume in the luggage compartment. The backrest of the three rear seats is also individually adjustable in six positions by up to 12 degrees. This means that the seat either offers
the option to lean back or positioned upright to allow for more cargo room.
mini countryman SE
In short things are more comfortable and inside – exactly the attributes that people buy crossovers. But this is a MINI and any increase in size is inherently noticeable by previous owners. There’s certainly a change but the overwhelming feeling we had was that this new U25 Countryman has been pushed gently outward creating a more spacious interior without sacrificing too much in the way of smallness – at least in its segment.
Additionally the rear seats can be folded down increasing the 16.24 cu/ft boot to 51.20 cu/ft – the most ever in a MINI. An additional floor compartment provides convenient space for the charging accessories in MINI Countryman Electric or storage in the ICE variants. The optionally available trailer hitch (finally coming to the US!) offers a towing capacity up to 2646 LBS or 1,200 kg.
U25_Countryman_074.jpg?resize=798%2C532&
The New Tech in the MINI Countryman SE
Where do we begin. The center of the tech experience is of course that circular display and MINI OS9. But there’s plenty more. Augmented Reality navigation, Level 2 Autonomous Driving, massaging seats and even a rotating reverse camera. MINI pulling out all stops to make this new generation Countryman a much more modern and thoroughly tech enabled car. And the good news is that all of it actually works.
Stationary the new MINI OS9 interface had felt intuitive in our previous experiences. But as we know, on the road things can be a bit different. In our experience we found a relatively short learning curve before we felt fully acclimated with the new system. Within the first hour we had quickly become accustom to the new interaction language and overall placement of functionality.
The standout feature however was MINI’s new augmented reality option within the navigation system. The augmented reality view overlays mapping graphics on a live video feed in the top of the circular display helping to literally paint directions on the road in front of you. On the bottom is a top-down map view which is perfectly synced with the video and gives you a full picture of where you are as you get clarity on when and where to turn. It worked flawlessly for us and felt like a game changer for urban environments.
Another great addition is the optional L2 autonomous driving functionality. Behind the glossy plastic where there’s a grille on the petrol Countryman are several ultrasonic sensors positioned on the horizontal strut that work in tandem with a suite of 12 sensors in total. Their goal is to detect the MINIs surroundings painting a much more clear picture of obstacles in a wider array of weather conditions.
With this system MINI has dramatically improved its active cruise that we’re told will be more weather proof and hehe less faults. It also allows MINI’s new Augmented Reality navigation to be incredibly precise in the complex environments.
When engaged, Driving Assistant Professional allows the driver to take their hands off the wheel at speeds of up to 37 mph (60 km/h), as long as they have their eyes on the road (as determined by an eye tracker) and are ready to intervene at any time. Once you reach 38 MPH the system switches modes and goes into a more simplistic autonomous setting which requires a driver’s hands to rest on the wheel. However the system works identically, following traffic, the curves of the road and will even change lanes based on the driver using the turn signal. As you can see in the video above system requires hands-on the wheel or at least pressure of some kind as a safety measure.
Finally there are a host of other small additions. The one that seems gimmicky until we tried it was the rotating reversing camera. MINI has never mentioned this in any official release yet the functionality is genuinely impressive and useful.
MINI Countryman SE Range & Charging
The electric Countryman SE is perhaps MINI’s most viable electric vehicle for the majority of its customers. That’s due two things; it’s size that will appeal to a broader range of customers and its range. In the UK that range is listed as 245 to 287 miles depending on how much urban vs highway driving you’re doing. In the US that is estimated to be to be a 245 mile EPA range. With either set of numbers it’s clear that the Countryman SE will be much more viable of a choice than the first generation Cooper SE with it’s 110 mile range (EPA).
The battery capacity in the electric MINI Countryman is 66.5 kWh with the usable size being 63.78 kWh. The 400v system allows an AC charging speed of 11kW and DC – 130kW. In ideal scenarios (charging at 130kWx) the electric Countryman SE can get from 5-80% in only 29min. In miles that’s roughly 23 to 184 miles in normal operating temperatures. While we didn’t need to charge our test car (our time was limited to a few hundred miles) that type of charging speed sounds fantastic. However the ability to recharge the Countryman SE quickly will be more dependent on the charging network than the car itself.
Mild Weather ScenariosRange Estimates
City – Mild Weather *535 km / 332 miles
Highway – Mild Weather *340 km / 211 miles
Combined – Mild Weather *420 km / 261 miles
Cold Weather ScenariosRange Estimates
City – Cold Weather *360 km / 224 miles
Highway – Cold Weather *265 km / 165 miles
Combined – Cold Weather *310 km / 192 miles
Indication of real-world range in several situations. Cold weather: ‘worst-case’ based on -10°C and use of heating. Mild weather: ‘best-case’ based on 23°C and no use of A/C. For ‘Highway’ figures a constant speed of 110 km/h is assumed. The actual range will depend on speed, style of driving, weather and route conditions. Data provided by ev-database.org
U25_Countryman_048.jpg?resize=798%2C532&
2025 MINI Countryman Electric Charging Speed
Charging speed is as critical is not more so than range depending on your situation. The electric Countryman SE supports DC fast-charging at up to 130 kW. This allows for a charge from 10 percent to 80 percent in only 29 minutes. While we don’t have US specific data, we do have European data on charging speeds which should give you an idea of what we’ll see with the electric MINI Countryman SE.
Charging PointMax. PowerPowerTimeRate
Standard 11.0 kW On-Board Charger
Wall Plug (2.3 kW)230V / 1x10A2.3 kW33h15m11 km/h
1-phase 16A (3.7 kW)230V / 1x16A3.7 kW20h45m18 km/h
1-phase 32A (7.4 kW)230V / 1x32A7.4 kW10h30m35 km/h
3-phase 16A (11 kW)400V / 3x16A11 kW7 hours53 km/h
3-phase 32A (22 kW)400V / 3x16A11 kW †7 hours53 km/h
Optional 22.0kW On-Board Charger *
3-phase 32A (22 kW)400V / 3x32A22 kW †3h30m100 km/h
* = Optional in some countries, standard in others. Check local specifications for details.
† = Limited by on-board charger, vehicle cannot charge faster.
U25_Countryman_021.jpg?resize=798%2C532&
MotoringFile’s First Review Take
In many ways the MINI Countryman SE is the most mature product the brand as ever created. In our time with the car we found it to be incredibly competent in every scenario from bumper to bumper urban traffic to motorway travel to Portugal’s best mountain roads. It’s not the fastest nor is it the lightest on its toes. And at over 4,500 lbs it’s about as far away as you can get from the iconic MINI Cooper. But in the growing world of electric crossovers it fills a void with a fun to drive, thoughtfully designed crossover with class leading utility.
While the $45,200 base price (US spec) is relatively well equipped in base form, it’s still one of the most expensive MINIs ever offered. But for the money you get a car that is miles beyond what MINI has ever offered. The level of sophistication in the drivetrain to the refinement in the tech goes well beyond what we’ve seen from the brand’s products in the past. For many potential owners the Countryman SE will feel like the ideal MINI daily driver.
As always an electric car won’t be for everyone. But with the new Countryman SE, range becomes much less of an issue as it has with the first generation Cooper SE. So the big question for individual buyers comes down to use cases and charging network you might need to support it. If you can make that work and need a little extra space, the electric Countryman SE might be your dream MINI.
U25 MINI Countryman Family – Technical Specifications
Countryman ModelCountryman E (EV)Countryman SE (EV)Countryman C (ICE)Countryman S (ICE)Countryman JCW (ICE)
Power204 hp313 hp167 hp221 hp (241 hp US)300 hp (312 hp US)
TorqueTBD364 ft lbs206 lb295 lb295 lb
Transmission1 Speed1 Speed7 speed DCT7 speed DCT7 speed DCT
Drivetrainfront-wheelall-wheelfront-wheelall-wheelall-wheel
Powertrain typeelectricelectricpetrolpetrolpetrol
Cylindersn/an/a344
Displacementn/an/a149919981998
Electric Power204 hp313 hp19 hp19 hp (NA – US)N/A
Electric TorqueTBDTBD55 lbTBDN/A
Electric Range (WLTP)287 miles270 milesN/AN/AN/A
0-60 mphTBDTBD8.3TBD5.4
Maximum speed105 mph112 mph132 mphTBD155 mph
WLTP l/100 kmN/AN/A40.9 – 46.3TBD34 – 36.2
WLTP CO2N/AN/A155 – 138TBD188 – 177
Length (mm/inches)4444 / 1754444 / 1754444 / 1754444 / 1754444 / 175
Width (mm/inches)1843 / 731843 / 731843 / 731843 / 731843 / 73
Height (mm)TBDTBD1661 / 65TBD1665 / 66
Wheelbase (mm)2069 / 812069 / 812069 / 812069 / 812069 / 81
Curb weight (LBS)TBDTBD3,571 lbsTBD3,825 lbs
Fuel Capacity L/GallonsN/AN/A45 / 11.854 / 14.354 / 14.3
The post Review: Electric MINI Countryman SE – The Range & Performance We’ve Been Waiting for appeared first on MotoringFile.
