2025 MINI Countryman Technical Data Including Weight, Power & Range
DimON
The all new MINI Countryman is bigger and more expensive than ever. But the technical data tells a story of a car that is much more capable with more performance and surpassingly good range (on EV version). Is it enough? Let’s look at the data.
The first thing that jumped out to us looking at the data is the curb weight. It’s up as we anticipated but (also as we predicted) not as much as you’d think given the size dan equipment increase. For instance the F60 2023 JCW Countryman weighs 3,688 lbs. Compare that to the all new U25 JCW Countryman at 3,825 lbs and you have only a 137 lbs difference. That’s likely due to the various weight savings measures that BMW built into the new FAAR platform including extensive use of aluminum and lighter steel.
205 mini countryman
The 2025 U25 JCW Countryman
Another area that surprised us was that the ICE powered JCW Countryman is not a mild-hybrid. The C has a 155 hp three cylinder coupled with a 19 hp electric engine. That combines to produce 167 hp with 206 lb or torque. The S (which we don’t have all the data on yet) has the same combo making 241 hp. However why does 19 hp and 155 hp not equal more than the 167 hp listed on the Countryman C? We’ll get that answer from MINI soon.
Countryman ModelCountryman ECountryman SECountryman CCountryman SJCW
Power204 hp313 hp167 hp241 hp313 hp
TorqueTBDTBD206 lb295 lb295 lb
Transmission1 Speed1 Speed7 speed DCT7 speed DCT7 speed DCT
Drivetrainfront-wheelall-wheelfront-wheelall-wheelall-wheel
Powertrain typeelectricelectricpetrolpetrolpetrol
Cylindersn/an/a344
Displacementn/an/a149919981998
Engine PowerN/AN/A156 hp / 4700 – 6500TBD313 hp
Engine Torque N/AN/A177 hp / 4700 – 6500TBD295 lb
Electric Power204 hp313 hp19 hp19 hpN/A
Electric TorqueTBDTBD55 lbTBDN/A
Electric Range (WLTP)287 miles270 milesN/AN/AN/A
0-60 mphTBDTBD8.3TBD5.4
Maximum speed105 mph112 mph132 mphTBD155 mph
WLTP l/100 kmN/AN/A40.9 – 46.3TBD34 – 36.2
WLTP CO2N/AN/A155 – 138TBD188 – 177
Length (mm/inches)4444 / 1754444 / 1754444 / 1754444 / 1754444 / 175
Width (mm/inches)1843 / 731843 / 731843 / 731843 / 731843 / 73
Height (mm)TBDTBD1661 / 65TBD1665 / 66
Wheelbase (mm)2069 / 812069 / 812069 / 812069 / 812069 / 81
Curb weight (LBS)TBDTBD3,571 lbsTBD3,825 lbs
Fuel Capacity L/GallonsN/AN/A45 / 11.854 / 14.354 / 14.3
Luggage capacity (liters)TBDTBD450 – 1450 LTBD505 – 1530 L
What else do you see that surprises you? And do you have some figures that we don’t? Let us know in the comments below!
205 mini countryman
The MINI Countryman E
The 2025 MINI Countryman Model Range
MINI Countryman – Electric ModelsDrivetrainPricingStart of Production
U25 MINI Countryman E Electric43.500€ 03/2024
U25 MINI Countryman SE ALL4Electric49.500€ 03/2024*
MINI Countryman – ICE Models
U25 MINI Countryman CICE (Petrol)39.900€ 11/2023
U25 MINI Countryman DICE (Diesel)42.900€ 11/2023
U25 MINI Countryman S ALL4ICE (Petrol)45.900€ 11/2023*
U25 MINI John Cooper Works Countryman ALL4ICE (Petrol)56.500€ 03/2024*
* Available in the US at launch
For more coverage of the new generation MINI released fall, check out the following articles and videos.
MINI Cooper EV: Premier | MINI Cooper EV: Hands-On Review | MINI Cooper EV: Video Review
MINI Countryman EV: Premier | MINI Countryman EV: Hands-On Review | MINI Countryman EV: Video Review
New MINI Family: 1st Look Video | MINI Circular Display & MINI OS9 Hands-On Review
MF_vector_gradient_BLACK_gradient.png?re
The post 2025 MINI Countryman Technical Data Including Weight, Power & Range first appeared on MotoringFile.
The post 2025 MINI Countryman Technical Data Including Weight, Power & Range appeared first on MotoringFile.
